The two holes are not for regular running or a tell tale.
The motor might have bugs(wasps nests)built up.I bought a used 85 and after setting for 3-4 years the wasps had a hotel working in the small holes.
Took out the thermostat and dropped it in boiling water, it opened and closed when cool
while I'm waiting for water pump kit I started it again and after I shut it down white smelly smoke came out the exhaust?
could it be steam?Update. I don't know how this is possible....I added Seafoam to the gas and now the water pump is peeing!! its pretty much as much water as the above video. BUT when I shut off the engine white smoke still coming out the exhaust. What should I look into now? Thank you all so much for your advice![]()
Your impellor was probably stuck and now it isn't? Anyones guess really, but gas and water are nowhere near eachother, so thats unrelated. Did you replace the waterpump?
