1981 evinrude E70ELCIH, bought a mfg 16 foot gypsy 4 years ago. Bad transom Bought 16 foot Sylvain put moter from gypsy on Sylvain. Took it out didn't get hole shot eventually would plan out and tech out around 45g.this year tried sync base timming but blew lower unit finally fixed that. Took out over weekend thought I had it down still stuck at 3g. Checked coils changed one.plugs one time too rich last time to lean pulled carbs clean as clean can get.changed plugs took back out tyres choking it sputters sprayed fluid all 3 carbs sputters.compresson cylinder 1-120 2-110 3 122. But I have noticed when I was at 45g charging was at 13.5 at 3g 12.5 trim up or down drops to 12 and slowly creeps back to 12.5.last year I crossed neg and positive blew rectifier and I replaced it.either iam not linking and syncing correctly or ignition system is falling .when I sync it timmer base all the way to black stopper at wot then adjusted 4 degrees less at idle calls for 19 degrees so I set it for 15
