Re: bayliner 2355 Ciera fishing?
Sure you can fish off of anything. String some logs together if you want or take a canoe out there. IF you are going to go that distance off shore and want to be somewhat safe and comfortable I will suggest again to lose the bayliner and get a real fishing boat,self bailing cockpit,low to the water in the stern area,twin engines,gunnels that will accept fishing gear,large fuel capacity. It is a lot easier to use a boat built for fishing to pull some tubers around than to take some generic cruiser and try to turn that into a fishing boat. NOT being to quick to say you cannot use the bayliner,but you will hate it in the long,maybe even short run for your intended purpose... I know what your original question was,just trying to save you the hassle of putting a bunch of work into a hull that is not set up for fishing off shore.
