my automatic bilge does not turn on when the switch is off? i don't have a 3 way switch just an on/off switch. as of now there is one wire hooked up straight to the pos terminal of the battery. its the wire coming from the on of switch. should there be another wire to the pos terminal to allow the bilge to pump when the switch is off(when the float switch activates it)
