Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
hello had some leaking from my 90hp Johnson was leaking from exhaust gasket under lower cowling so i took a look and tightened the 6 bolts and one of them spun and it not threading guess it corroded bolts not broken this mean i need to remove PH? or can i try a longer bolt?? any thoughts ? thx
I'd think that JB weld would just make the leaking exhaust take a different path than directly out the bolt hole. A longer bolt wouldn't help since the factory gave you the right size bolt for the hole they drilled and tapped. What boobie suggested is the best way. The least worst way would probably be to trailer it to a machine shop and have them drill it out and tap it to a slightly larger bolt. Inexpensive and easy. Depending on the condition of the gasket though you might not have much to gain from just having a bolt clamp two non-sealed mating surfaces together.
i looked twice can't tell is this mid-section to power head gasket? if so looks like you have enough room to work without pulling powerhead. you will have to enlarge hole in mid section to get heli coil in.and may have to use a washer or a bolt with larger head but it should work
Just let a machine shop do it. They can drill it out larger, tap it, and give you a new bolt for about as much as you'll pay for the bits you'll chew through and the heli.
ok sounds like a good idea ill try and find a machine shop that will do it in my area the gasket seems fine i think with the bolt tight should be ok thx alot everyone
