Re: Borg Warner Velvet V Drive Reverse Rotation
good thing I dont do this for a living
however,other than a few models most modern clutches CAN be converted for left or right output with a left hand input.
like I say, its how its been done for the past 10-15 years.
there are a few models that CANNOT be converted but its stated in the manual. I dont think the 1.5/1 is one of them that cannot.
most modern circulating pumps for marine use are bi-directional. to convert from left to right rotation will require the correct cam,correct distributer correct starter and the correct rear main seal.the use of a left hand seal on a right hand engine will create a leak.
over the past 10 years I have set up quite a few boats with 2 left hand engines and counter rotating props. getting right hand bigblock GM's has been mostly impossible for the past 10 years. you can still find the odd 5.7 in right hand but no 7.4,8.2 or 8.1s in right hand rotation.
if you install a pair of big blocks you will convert the clutch or replace it with a convertable model.
