I used this stuff from quicksilver that is supposed to clean out the carbon build up. Well after following the directions on the can I noticed that when spraying it into the upper carb it would not choke the engine down as it would when spraying into the bottom carb. Is this a firing/ignition problem or a carb problem?
Thanks
Joe
Thanks
Joe
