I have a Cat 3412E 1300.
the engine overheated and the alarm sounded
i switched off the engine and waited for it to cool and checked the impeller and in wont spin when cranking the engine.
i removed the impeller and cranked the engine and the shaft spun??
i put a new impeller on and cranked and no action??
the teeth for the shaft and the impeller are both good so i am thinking the shaft will spin but not under extra load with (the imperller
i removed the impeller again and took some vice grips and put them on the shaft and i was able to spin the shaft freely in clockwise or counter clockwise directions this cant be right can it?? this would mean i am turning all the gears inside the engine.
any help would be appreciated
cheers
cheers
