Troubled boater
- Aug 11, 2017
- 15
Hello guys trying to check coil under flywheel the coil I'm trying to check is the one that has two brown wires going to the duel spark plug coil I know I should have a dva but I don't so I used my meter to check ohms 1 wire has 498ohms and wire 2 has 847ohms almost 400ohms differents does that mean the coil is bad the problem I'm trying to solve is no sparkabove idle or misfire above idle thanks any suggestions would be appreciated
