Re: City outlawed me owning boats or working on them (MN, USA)
Okay, here's my picture post(s) as promised.
A couple things about these pics: First, the boards you see piled up near the house are from this weekend's work, specifically yesterday's, clean out of part of my basement. They're mostly gone by the time you read this, and will be completely gone by tomorrow night. Same thing for the yellow strap on the ground by the garage and the few bits of trash by the wood pile/garbage can house.
The camera I used for this has a wide angle lens, which distorts pics just a little, but lets you see a lot. Sorry for getting my hand in the pic so much too. If you click through to photobucket you can see a lot more detail in these. I'm planning on going through the yard with a fine tooth comb just to make sure there's nothing the inspectors will call out as a problem, other that the stuff we disagree on, in the next 9 days.
You can't tell because of the snow, but I just finished landscaping last month. About 2/3 of the back yard is bare dirt with tire tracks for the moment, and although I've created a new berm/hill in the back corner of the yard (to the left of the cedar tree) I haven't finished shaping it yet... that'll have to wait until spring weather. In any case, the city isn't complaining about that at least at the moment.
Here's the view of my house from across the road, as requested. You can see my dented old truck and my honda civic in it. The 28 foot boat is in front of the truck, and the thing in front of the civic is my engine hoist:
Here's a pic from the middle of the street, provided for an example of the drive-by view:
And here's one from the middle of my driveway, a view no one but me should be able to see legally:
Here are my trailers... the one on the right is for the 28 footer and is currently missing fenders due to an accident (a railroad tie tipped over on it and twisted them). The hoist is a home built trailerable unit. The hitch is clamp on and not attached at the moment. The boat trailer is licensed legally, the city just wants me to put my name on the registration. The hoist I'm working with the state to license, but the city says it's "commercial equipment" that I'm not allowed to have.
As long as we're here, this is a pic of the hull of the 22 footer that I've rebuilt. The upper half of the hull and top cap were molded from scratch in projects detailed elsewhere on this board - you can still see which parts are new in these two pics. The interior structure was completely replaced with epoxy and plywood instead of the waterlogged poly and foam that was there. I can't wait to finish her... if I'm allowed to keep her, of course.
Half the hull has been painted with white tinted epoxy on the top and black (graphite) on the bottom. The black will stay, it's meant to be a tough bottom coating. The white epoxy will be used as primer, so it'll be sanded and wet sanded to form the final surface.
Turning to the right, here's a pic of my Bayliner. The damage to the hull is from a collision with a wing dam, so it's about a 2 foot by 2 foot section on each side of the bow I'd need to replace. If I was allowed to work on it, that is. It's not a simple project, but it's well within my skills I think. There's a little damage to the starboard hull side you can see aft here, from scraping against the dam. That plus the snapped off pulpit are the only damage. The stringers are dry (tested and drilled) and the interior is dry if a bit musty. I pulled out the engine and removed the sterndrive to reseal it, all else is still installed.
I'm not sure if this new forum software allows 6 pics or what, so I'll end here and start another post shortly....
