Wow, well that seems too easy!!!![]()
Don- coerrect me if im wrong but arent these sbc's internaly balanced?
The bigger flywheels are better for high compression or large cubic inch engines. Other than the bolt pattern (and low torque verses high torque starters) the starters are the same.
The starter will spin the engine faster with the 153 tooth flywheel, but the starter has more "leverage" turning a 168 tooth flywheel, therefore turns the engine over with less amperage draw.
I don't know if balance will be a problem or not, i was just suggesting you check it for vibration before putting it in the boat.
well it was confirmed by three sources that my flywheel will be ok to use..
Man i learned A LOT today haha
Great, I learned something to.
I would still run it on the floor before putting it in the boat. Of course I do that on every engine I install, and have for years. Then I know there are no leaks, or running problems before installing.
well it was confirmed by three sources that my flywheel will be ok to use.. the gm 350 changed in 1986 from a two-piece rear main seal to a 1 piece for leak reasons..therefore the crankshaft flange changed as well and added a small counterweight to the flange, its a misconception that newer 350s are externaly balanced when they arent. the 350 is internaly balanced and either style flywheel will work. its the 383 strokers and 400 small blocks need to be externaly balanced to acount for the extra rotating mass. also i wil add my engine has no weights on either the balancer nor the original 14" flywheel thus also confirming this...Man i learned A LOT today haha![]()
