Cooling ?
HT32BSX115
Re: Cooling ?
It should.......
Merc did put an Alpha on behind a 454 that year, I have to assume that it did "cool" ok......
starsnstripers
Re: Cooling ?
I was told it may overheat at idle and might have to ad one of those check ball kits to the housing. I guess i'll try it and see. I can't seem to find the right part# for the check ball kit. I have the screw in 'T" not the t thats part of the casting. Not sure if they have the same check ball kit, or if the length will be correct?
Don S
Re: Cooling ?
That type thermostat housing doesn't need the check balls, even if you found them, you wouldn't be able to install them.
