to make a long story short, i had a knock coming from one cylinder on my 2000 115hp yamaha. did a compression test, test came back at 3 cylinders had 120 and one had 40. took the heads off and noticed the piston was damaged as well as the cylinder wall. so my question is roughley how many shop hours should it take to replace 1 piston, rings and bore the cylinder wall 20 over. I just got an outragous estimate from a tech at 2900.00 for this job, witch sounds way to much. to break it down parts would be about 225.00 and labor would be 2700.00, or he could rebuild all 4 for 3300.00 Any responses would be much appreciated.
