I am disassembling the CR lower unit on one of my 1988 Evinrude 225's to replace the seals and inspect the internal parts.
I do not have the special tool to thread onto the prop shaft that attaches to the slide hammer to remove the prop shaft and carrier. Anything commonly available that will work?
I also do not have the special puller that clamps to the driveshaft to pull it out. Any easy way to get that out using commonly available item?
If all else fails I can probably fabricate something that will work, but I hate to spend all day making a tool to do a ten minute job.
