Custom Fiberglass Extended Swim Platform
AShipShow
Have you thought about trying this? Could make the same thing as flex mold and it would match existing non skid on your boat
tpenfield
Yes, I watched that guy today. My challenge is getting about 32 sq. ft. of non-skid pattern. It's pretty straight forward if you need a couple of sq. ft. for a repair, it seems.
tpenfield
Progress Update:
I got the foam 'plug' roughed out. I used 2" thick EPS sheets, glued together with PL adhesive.
Click image for larger version  Name:	IMG_1463.JPG Views:	1 Size:	199.7 KB ID:	10652436
Click image for larger version  Name:	IMG_1464.JPG Views:	1 Size:	192.2 KB ID:	10652438
Next steps are to . . .
Fill a few voids
Fillet inside corners
Sand to shape
Coat with epoxy
Apply non-skid material - still trying to figure out the best (and economical) thing to use
Final epoxy coating
Prep for mold making
Looking good
you can use the low expansion foam spray for filling voids. you can also use spackle.
mickyryan
what is the support going to look like for this , that's quite the cantilever, remember to do calculations with adding the force that could be exerted at furthest point away from fasteners kinda like a breaker bar on a bolt
tpenfield
There will be 3 stainless steel tubes that go from the outer edge of the platform (underneath) down to the transom, similar to most extended platform installations.
dezmond
Looking really good.., Drywall mud works really well as well for filling voids...
tpenfield
Good idea. I think Scott also mentioned using spackle/joint compound. I am thinking maybe I could use it to shape the inside corners as well as fill voids, etc.
dezmond
Yep.. I was talking with a really good fiberglass guy and he helped me along with my mold I was making for my dash. Used the blue foam for rough shapes, applied drywall mud in thin layers to build up and sand to final shape.... Works good.. Just don't put it on too thick or it will take a long time to dry and will also crack.
Like this project your doing. following along for sure!!!
Woodonglass
Plaster of Paris would be my choice. It's designed for molding and doesn't crack to bad.
Modeling Clay also works well.
sphelps
If you use joint compound /drywall mud use the 20 minute stuff to get it close then skim with reg to sand
tpenfield
Finished the rough shaping today . . . .
I will be filling a few voids and then doing some final shaping.
Couple passes of fiberglass tape and spackle and you can coat with eeeeeeeepoxy
CarTuner
If you haven't bought the epoxy yet, lookup EBond Epoxy in South Florida. Extremely reasonable pricing and nice quality stuff. I just got 2 gallons of their 1285 Laminating Resin and 1 gallon of hardener (2:1 ratio) for $82 + tax. That's $27/gallon of material (cheaper then polyester!).
FGCI has boat resin for about $25/gal
tpenfield
Progress Update:
It has been a few weeks (maybe more) since I have updated my thread. I have been working on & off (mostly off) on the swim platform 'plug'. I am using joint compound to fill in gaps and smooth out the surfaces.
Here are a few pictures:
IMG_1612.JPG .
Next steps are to do a final coating of compound and then sand. Epoxy will be after than, and more sanding.
Woodonglass
If you have any CSM scraps you can shred it and add the fibers to the compound to help avoid cracking. Drilling some 1/4" holes in the foam will allow the compound to get a better bite and cut down on flexing/cracking.
garbageguy
Regarding the idea of observation hatches raised by another - maybe have vented cover to relieve pressure that will build up and be noisy when not underway? The platform on my boat is similar to your existing platform, and it gets noisy. I like your extension, makes me think...
