Re: Decarb?
Hi Tommy. Not much to add to the good advice they gave you, but if you do a lot of idle operation, decarbon frequently. If you are allways wide open throttle, you would normally never need to decarbon. But the average boater needs to do this every 80hours or so.<br />Idling allows carbon to build up in the engine, under the ring lands and inside all the ports.
