dieseling
rocky100
My 3.0 litre mercruiser has started dieseling after I turn it off.
Never did this before---and I am buying gas at the same Shell station at the lake----do u think it could be the stabilizer in the tank left over from winterization?:confused:
Don S
Re: dieseling
Have you tuned it up and adjusted all ignition and rpm's to manufacturers specs? Could be more specific, but the 3.0L engine has been used for a million years and gone thru many changes, what year is yours?
JustJason
Re: dieseling
Everything Don said + check your idle rpms.... to high will cause a dieseling situation.
chiefalen
Re: dieseling
these guys are good real real good.after running it let it idle for a minute or two before shutting it off.
wkb2460
Re: dieseling
Did your marina change the octane level of it's fuel?
My 3.0 used to diesel on 87 octane only.
chiefalen
Re: dieseling
ouch marina gas prices.i use wa wa gas on the way home from the ramp.i still complain.
