I have a Suzuki 115 1988 year model tore down for bad #4 piston and lower crank bearing and rod problem. Thanks to Rodbolts info, I have just recently had Ackermann Marine, Wilmington NC repair the crank and rod assembly;bore and hone #4 cyl. My question is, on reassembly of this power head should I Disconnect the oil injection and pre-mix or continue to use oil injection. Any ideas on what could have caused this problem which occurred before I bought this boat. Also if I pre-mix what ratio should I use.
