Hi all, I need to determine the year of this model. I am getting returns of 1982 but not sure?
It was not pumping water. Due to an oxidized bolt there is a spacer plate on which the water pump sits that cannot be removed until the bolt is drilled. i have never seent his set up before of having a needle bearing directly underneath the water pump. You will also notice a metal compartment beneath the water pump on the upper leg has broken in some places, Is this part still availabe? Any assitance appreciated,
Paul
Paul
