engine balance issues...?
Gitrdun01
okay so I replaced a 1995 ford 302 fi with a flat tappet cam and 2mae crank with a 302 long block I had built with a roller cam and the same size 2mae crank. Engine sounded good but started to vibrate about 30 seconds into intial start up then got worse to the point even me being a novice new something was wrong. As I went to turn the key off it settled down but was still vi brating and then I noticed the vibration dampner and pulleys had a wobble to it...I un-installed and re-installed it thinking it was my own shotty work. still looks bad up and down and in and out. So my thinking is dampner is bad and I find out part is obsolete no luck on ebay either. I then go to a machine and engine balance shop and he looks at it says its fine nothing wrong with it but looked up a replacement for me anyways as he does he mentions its a.28 oz balance. What? This crank is supposed to have 50 oz bal. Okay so no biggie ill get a 50 oz. and put it on there. Grrrrrrr wouldn't you know that the 50 oz. is a 4 bolt pulley instead of a 3 bolt. Now I can find no combination of 4 bolt pulley and spacers to get me where I need to be to line up with wtr pump pulley. So my question is am I missing something? Has anyone ever heard of this before? I pulled the engine back out to check the balance on the flywheel it has a 50 oz. Bal. Ummm wierd. Have I been FRANKENSTEINED?
Gitrdun01
Re: engine balance issues...?
Whoops left out some crucial info this is a 95 omc cobra fuel injected 50faphub I was told it was 230 hp thus the "e" series crank. Does anyone know if the original dampner was 50 oz 3 bolt? I bought this boat used and have no idea if someone has changed anything. Original engine ran good but Ltl gutless in lower rpm if loaded down with people. Has had a weird idle since I've owned it but I never watched it run with the engine cover off either. 2 yrs ago it and started making a light ticking that this year turned into a mix of ticks and clunks( valves and rod were fine which is what it initially sounded like vavle knock but no one could agree where the sound was coming from right, left,top end bottom end needless to say 5 wks ago kaboom then I had a nasty nasty sound and still the ticking and clunking mixed with the schreech would be the best description... Broken piston and bent piston pushrod that wore its way into the block I assume from a bent crank from having the wrong weight balance?
