engine froze
tbirdkidd
I just picked up an 1986 85hp Force outboard that has been sitting for 5 years but I cant get it to turn over. Could it be rusted the guy that gave it to said it ran when he stored it (outside). Any suggestions?
Elbo
Re: engine froze
Naw! Pull the head and see if the pistons are rusted to the cylinder wall.If the are I like to use marvel mystry oil to soak em.Just fill the cylinder and let it set.After a day or so tap them with a block of wood to see if they will move.Keep doing this till they do.You can break a ring doing this so be easy and she might free up.
Elbo
Re: engine froze
kenmyfam
Re: engine froze
You are in the wrong section for this motor.
Oil it up and see if you can get it to move. If not then I would convert it into a parts motor to benefit the unfortunate folk that still have force motors. Use the money towards another motor.
tbirdkidd
Re: engine froze
Elbo
Took it apart and it is just rusted from improper winterizing, removed the cylinder rust and freed up the pistons. Now that it turns over should I go into the crank and replace rings and bearings. Also should I hone the cylinder wall they cleaned up with fine emery pretty nicely.
wilde1j
Re: engine froze
If the bearings and crank journals are rusted also, it's junk.
