- Jul 23, 2011
- 52,085
There is no direct correlation between carb size and pitch
Your motor is an air pump. Just like your lungs are. Now put a snorkel in your mouth and try to run ....you won't get vary far breathing thru the snorkel. You get the point
Somewhere in the past a 600CFM carb was installed vs what was on the motor prior. And you now can't get on plane
Because the carb is now your restriction to get the motor to spin fast enough to do the work needed, you may have to drop pitch to get your boat on plane
Install a vacuum gauge in the intake and go for a run. If at WOT you have any significant vacuum, the carb is too small. A properly sized carb will get you to about 0 - 0.5" of vacuum at WOT and get you to full RPM
If it was me, and the motor is healthy.....I would put an 850 annular discharge carb on it
