Everything done but low rpm at WOT. Distributor spring?
Lou C
You all got me to thinking so I pulled out my 1988 OMC shop manual & it looks like you should have a 750 CFM Marine Holley!
kenny nunez
Can you post a picture of your carburetor with the flame arrestor removed?
Does this boat stay in the water? If so, how clean is the bottom?
Lou C
It should have J tubes for the bowl vents if it’s a true marine carb.
post #12 had the carb number
Carb is 4bbl Holly 1850-5. Numbers on the horn are 1850-5 1692
its a 600 CFM Holley Street carb with brackets for the kick-down linkage
VancouverBoat
Just to see if the shaft was moving to open the Secondaries, I would place it where movement would cause it to slide down the Shaft, as the Actuator moved upwards.
Some quick scans from Prints. August 16, 1986.
Houses on the shore in you Pic are massive now..
VancouverBoat
what color are the plugs.
new isnt a color.
white, coffee, or black.
if your plugs are white, you are way way too lean.
measure the rocker arm movement with a dial indicator. your valves should be moving almost 0.550"
Plugs were just put in about 50 hrs ago but I can't check them again because I have to remove manifolds to remove plugs. I just replaced the manifolds for $6000 so I would not like to do that again. Rpms were same as before new plugs. Plugs at that time were coffee mostly. Not bad.
VancouverBoat
Scott mentioned that way back in posts but there was some debate that I should still get enough air and fuel. I was getting no vacuum at wot so that seemed to indicate to some that I was ok at current cfm.
VancouverBoat
Please see pic. Bottom just hauled in may and new anti fouling
Lou C
Doesn’t look like a marine carb. No j tubes for the bowl vents & no fuel pump overflow hose…the nipple is on the flame arrestor…...
jimmbo
It is not a Marine Carb, that was determined the moment the OP stated that it was a Holley 1850.
kenny nunez
I hope that your fire suppression system is in good order. If that carburetor should ever “flood over” you will have a fire. The carburetor is not Coast Guard approved. And as others have stated you need the correct one as Lou pointed out.
VancouverBoat
Yes, understood.
jimmbo
Is there a chance that having 2 throttle controls is inhibiting the Carb from opening far enough to make power? Have you ever tried running it with just one set of controls connected?
VancouverBoat
Yes, I have tried that. I have triple checked and the throttle lever to the carb is rotating to full stop.
jimmbo
FWIW
At 100% Volumetric Efficiency a 460 cubic inch inhales 230 cubic inches per rev. so at 5000rpm it would inhale 1,150,000 cubic inches of air, which is 665.5 cubic feet. However since very few Naturally Asperated Engines can achieve 100% VE... I will be generous and allow an engine from the 70s to have a VE of 80%. So 80% of 665.5 cu ft is 532 CFM. I was also being generous as to the 5000 rpm, as I doubt OMC's WOT range was even up to 4600rpm
VancouverBoat
Thanks, I think I understand now some the difference between regular and marine carbs. We must be in the wild west up here in Vancouver BC because I would bet that there are many older boats up here running with regular carbs. There probably should be regulations, but I cannot find any regulations that regulates what carb can go on a used boat. I have had tons of used boats and never knew to check if the carb was a marine version.
