Hi, I have today mounted my Evinrude15hp generator model 155005C (1975 i think)
I ran it using hose & ear muff things & it runs ok considering it's not been run for 4 years, I have a few questions that im hoping someone can answer:-
1. where does the engine expell the cooling water from, there is no water coming from the exhaust ,but there is a jet coming out from the rear top of the leg when the engine is running, when the engine is not running there is water coming out approx 6 inches above the water intake on the right hand side as you look at the rear of the boat .
2. Should the wires from the generator go to the battery.
3. The engine is noisy like a motorbike when run with hose , will it be much quieter when the leg is under water??
Thanks Bryan
Thanks Bryan
