My port side motor will not tilt up when I went down to the boat today. I hit the tilt switch and nothing happens. It makes no noise at all. I checked over the fuses in the boat and switched the relays and still nothing. Any ideas??
I have power all the way down to the last length of wiring going to the tilt motor. Since the boat is in a slip, I can't trace it any further. I also supplied 12 volts straight to the wires, and nothing happened. I guess the motor went - is it normal for them to just fail without notice?
