Evinrude Problems
Keith Bowden
Re: Evinrude Problems
Like with most things theirs a learning curve, my apoligy you can remove my posts
Whatthe
I just pulled the fuel/VRO pump and took apart the gas side of it and I think it is in need of a repair kit is it possible to get one????
Whatthe
Just rplaced vro/fuel pump and gas/oil lines still loosing power at WOT :confused: <br />Don't know what to do next
Whatthe
ok can any one answer this one <br />started up motor advanced to wot motor bogged placed hand over lower carb throat and the speed picks up. is this due to a fuel air leak????
walleyehed
Have you checked the inlet into the bottom carb for security??? It "could" be pulling some air if cracked or loose.<br />This could also indicate a plugged main jet, which I would most likely pull asap and check.<br />Do I understand correct, that you replaced the VRO??? or just the hoses??
Whatthe
I have replaced all hoses from tank to carbs also new tank.<br />did not replace the vro just put in a kit for the fuel side had a part on the gas side that was broke and replased it.<br />How do I go about pulling main jet and how do I check if its plugged???
Whatthe
my jets are not adjustable <br />I pulled parts view and prats list from evinrude to try and find the jets but they only show orifice idle,air bleed and a orifice plug
walleyehed
I know it's not adjustable, but you should have a high-speed orfice in the bottom of the bowl...should be under a plug on the side or front of the bowl at the bottom. There will be an "Orfice plug" to remove, then the main jet will be behind that.
Whatthe
ok that I beleave is the plug that is located in the front of the bowel.<br />so i remove the plug screw, the washer and than the orifice correct? what is it that we are looking for after i remove the orifice or is just removing the orifice and replacing it?
Whatthe
pulled both carbs this is what i have found so far:<br />1) upper carb main jet ok but float assy shot<br />soaking now will rebuild <br />2 lower carb mainjet stuck in carb had to get new bowel float assy ok working soaking and than rebuild<br />3 I bought new main jets just in case and they gave me the wrong ones any idea what they should be?<br />I cant read the one from upper carb looks like 54?<br />any thoughts on this???
Whatthe
ok I got the main jet out of the lower bowel it looked clean (now I have a extra bowel) any way will rebuid carbs tomorrow. oh buy the way i id. the jet # they are 38D for the main and 40 for the air im going to replace all jets.<br />So my question is do you think the float on the top carb was my problem?
walleyehed
It "could" be...you need to call a dealer and check on what the stock jets were if you haven't already.<br />What about the float that is "shot"???what are you refering to?
Whatthe
the float valve has a clip attached to the float and in my case that clip was missing, also the nozzle gasket was all chewed up
Whatthe
Kenny: I would like to thank you for all your help you gave me to get the Evinrude back up and running. The last couple weeks has been very exciting with your guidence I was able to do it my self and that means alot to me. :) :) :) :D <br />I will be out fishing Fri. thanks to you<br /><br />Again Thanks<br />it was the carb But I know alot more about my eve so it was all worth it.<br />Dennis :cool:
