Re: F R- Can you answer this one?
How did you get that shock absorber apart??
So I figured out after looking at a diagram that is a bearing plate. After digging into the lower unit a little deeper I made some discoveries. The shift detents are both in tact, the shift rod was bent so I bent it back. All good now, the gears and dog look good so no gear worries. The shock absorber is indeed broken.
So I guess whoever owner this motor in a frustrated state hit a rock, shock broke , came up and hit the bearing plate and probably bent this shift rod all at the same time or after it broke tried shifting it. No wonder it wouldn't "go" anywhere.
