Hi everyone,
I have a 1981 Ranger 320-V Comanche that I purchased as my 1st boat a year ago. When we purchased the boat, we noticed a prior hull repair...but it appeared to be solid...and the price for the boat met our expectations...so we took a chance on it.
I have observed a small amount of water coming into the boat each time we take it out. Today, I was out about 90 minutes, and when I pulled the drain plug, I had about 3-4 gal drain out.
I took another look at the old repair, and now see a definite failure in the general location of the original repair. It appears that the original repair extends 3 feet or so along the keel. The spot that is failing is about 3 inches long.
I am pretty good with DIY projects, and hope to take care of this repair myself, even though I have never worked with fiberglass.
OK - what advice would you give me?
Take it to a shop, and pay the price to get it done right? If this is your advice, what would a rough price range be?
Or...should I take a cut off/angle grinder to it and do it myself?
If the latter, what are the steps? Being a novice...I would probably do the following:
1. Use the angle grinder and open up the defect "a little"...no more than necessary to get new fiberglass repair to bond.
2. Use a putty knife to force the fiberglass repair compound into the repair cavity
3. Perhaps lay a thin sheet of fiberglass repair cloth over the repair
4. apply more fiberglass repair compound over the cloth
5. Let cure
6. Paint/gel coat
Ok - blast away...how much do I not know?
What are the names and brands of recommended products I should use?
Thanks for any advice.
5. Let cure
6. Paint/gel coat
