proshadetree
- Jul 19, 2008
- 1,887
Re: First engine rebuild
Pistons must be feeler gauged at minimum. I used a inside mic 1 inch down bore and an outside mic at the top middle and bottom of piston to determine. Piston placed in bore 1 inch down and a thin gauge used is about the minimum way to do. If you are referring to rod bearing clearance, anywhere comfortable in the revolution should read the same.
