Fish Finder
Mark_VTfisherman
Re: Fish Finder
......If you view the HD lake maps, they have allot of info. Unfortunatly, they are usually only a dozen or so per state. Generally, always bigger waters. Most small and many medium size lakes, have very little detail. ............I just want to buy one map, and use it eveywhere, PC, chartplotter, or print. Be able to update it and add crib notes, along with waypoints and markers. :)
Most of the maps are taken from old paper maps which were drawn with info sounded by drop weights. The HD maps are actually electronically sounded by sonar and recorded with GPS data. Standard "Base Maps" have proven quite inaccurate here in Vermont; our tolling patterns have recorded us as passing hundreds of feet ashore across dry land!:confused: the maps sometimes don't match the GPS data. I don't know why. I have not seen the Navionics info do that.
If I had the time, and the money for new computer and software, I could be all over the make-your-own-map stuff. I think it would be so cool to record GPS data simultaneous with my sonar feed, export it to my PC and save it for notes and merging later data:cool:. But I have no idea what that would cost to get set up to do that of if it is even commercially available to do that!
More power to you but I need to keep it simple and just fish for now, but I could probably learn a lot from you!
jonesg
Re: Fish Finder
Convinced I had to own one I got a lowrance with cape cod data map, I get a headache trying to figga it out, way too many bells and whistles.
Went out 4 times last fall and forgot to even turn it on, so I still don't know how they work on the water.
John_S
Re: Fish Finder
Yea that would be cool stuff, but I think you are talking onboard laptops and recording. Griding out a whole lake is much more time consuming, and would certainly impact fishing time! ;)
My HB has a recording mode to SD, where you can view latter and then set new markers on interesting stuff you might have missed as it scrolled off screen. While I am still learning what all it can do, it is helpful for setting multiple markers to provide orientation of underwater objects. ie you can mark the endpoints of a log, such that you might be able to parrellel cast to it, vs just cross over it.
BTW, I have heard of some similiar issues with Navionics, dry land, etc. I believe most of that is offset/datum adjustment.
Mark_VTfisherman
Re: Fish Finder
....My HB has a recording mode to SD, where you can view later and then set new markers on interesting stuff you might have missed as it scrolled off screen....
So do you mean later on the sonar/GPS or on your home computer? I just tracked down this thread looking something else up and saw your follow up post for the first time.
Thanks- Mark
John_S
Re: Fish Finder
Thanks- Mark
You can play it back on the unit and set waypoints. Even if you dont record, when you press the "mark" button, it will do a screen save to SD card, which you can view on unit or PC latter. I also believe there is some 3rd party S/W to view the SI recordings on a PC. Using the HB PC s/w you can download nav data from unit or SD card, and interface with Google Earth. You can click on a saved waypoint and press the google earth button, and it will go to that cooridinate. You can also upload new waypoints and routes from PC to unit, but I haven't done that yet.
wanna-be
Re: Fish Finder
starting to look for a combo again (6 months later). last time i got so overwhelmed with all teh details i don't understand i just gave up. but this thread help narrow to the Hummingbird 580combo vs 587ci combo. does color make a big difference in viewing/interpreting?
