Re: Flotation - some better than none?
aeviaanah, any foam attached will help. If your boat flips and some air gets trapped under the bow that will help float the boat. If you have closed cell foam elsewhere too then more of the boat floats. If your hull weighs 150, the engine 120 and the battery 60 then you need to float 330#. The fuel tank is almost neutral as the fuel is lighter than water and any air in it is much lighter. People are neutral bouyant. Loose gear will fall out or add some more foam to cover what is going to sink fast. If the metal hull fills with water it is handy when you can retrieve it without a Scuba set.
