I replaced my 507X5A with this 507X8B that I bought used out of ebay. I wired it up per the colors but I wonder if something is different at the switch than my old motor. Two issues now: 1) Coils smoked badly and smell of smoke. 2) Motor started right up but would not shut down with the switch. Had only run for a few seconds so it died when I idled it down. This used motor was available because it slowed down after running at WOT for a short time. Said to maybe be a feul issue so didn't seem to be to big a problem.
So now what? Is this something with the wiring or was the original problem a coil issue? Both coils are distorted, one has fluid leaking out. To start, can anyone give me a listing of what I should expect to have with a test light or volt meter at each pin of terminal strip with key on and key off? Other suggestions? Guessing I'm going to need coils regardless, hopefully I haven't wrecked anything else. Compression is 118 PSI.
