Re: Force 85
if your battery is fully charged,all cable connections good, then your starter is probably in need of brushes, or replacement. with the plugs out there is no load and will spin like crazy, but with plugs in the load in spinning the flywheel is greatly increased with the engine compression, so a weak battery, bad connects or bad starter will cause the problem good luck don
