Re: force performance?
Hi Bassy Jr
First off, you do not had a 1988 120hp motor.
They did not make the 120 hp model until 1990.
So you motor is newer than you thought.
If you can find the model number and serial number, post them, and we try to pinpoint the year for you.
As for the performance and fuel issues:
What are the highest rpm you can reach with your motor?
And, a worn out fuel pump can leak fuel into the engine, causing it to use more than it should.
The good news is that the rebuild kit is under $20.
