- Jul 23, 2011
- 52,462
yes, then you turn itSo upside down is possible
Running at idle I have just under 5 psi. I will check wot this weekendI'm going to install an inline fuel pressure gauge and see what's there.
That’s perfect if it holds close to that at wot you are goodRunning at idle I have just under 5 psi. I will check wot this weekend
So no more pinging? You had verified fuel contamination and may have to clean out the carb would be my first thought (unless you did clean it already)Alight here it is. Took boat out today and it started nice and kept running great so choke adjustment worked. I have full fuel pressure at wot..how ever when I went to take off for the first time after warm up it was really sluggish. I set timing back to 10 dtdc. Took off better but still somewhat sluggish...third attempt to take off...no problem and for the rest of day all good...perhaps connection issue somewere
Would think either rebuild or replace the carb or go back to 8 deg BTDCStill a slight ping at wot...if I back off about a 1/4 inch it stops. I don't run full blast anyways
the difference between 8 and 10 intital timing wont be that significant, would suspect that is a red herring and something else is going on. Given what you saw in the fuel tank would think poping top on carb would be in the nest stepI couldn't take off at all at 8
@Scott Danforth has been threatening for years to buy my old 3.7's for his imaginary projectThis will make you feel better about your boat- took me 30 years from when I bought it as a non running/ non driver project to get it road worthy..
I suspect the same stuff that was in your fuel tank got into the old carb.Just fired boat up on muffs and it's night and day of how it runs. So smooth. Test run monday
with inflation the value of a well used 3.7 has never been higher …@Scott Danforth has been threatening for years to buy my old 3.7's for his imaginary project
you still havent given me the price other then beers and sammiches...@Scott Danforth has been threatening for years to buy my old 3.7's for his imaginary project
