Ford 302 pinging
Jakem
Update on this topic. Hit good weather and took boat out. I used higher octane fuel...the new carb..cleaned all connections. Still had the slight ping at wot. Set back to 8 btdc. Took off good and also at wot ping gone and seems I gained some rpm as well. Also seed even cruising at 3000 it ran smoother. So thank you fellows for all you.time once again.
