- Mar 8, 2009
- 43,448
More good and Bad news
The good is I'm pretty sure that all the water came from an unsealed area around the new water tank put in a few years ago. First I see it as a bad design because there was no sealent used to keep water from seaping between the tank and the foam. In the original design Formula used an aluminum tank which over time developed pin holes. I replaced it with a plastic one and in doing so I sort of caused my own problem. I didn't use any sealant mainly because Formula didn't, figured they knew better then me, Well they used aluminum and the foam would stick to it, but it wouldn't stick very well to my plastic tank.
I drilled several test holes all along the inside of where the water tank was and found it to be damp about half way up toward the bow. Drill holes on the out side of were the tank was and it's dry. Pulled off some more of the engine bulkhead wall on the port side and it was dry on both sides. It is also dry under were the water heater is sitting. So looks like finish ripping out the board in the water tank area and then let it dry out and see what else I need to do and develop a plan.
Now the Bad, I was drilling two test holes in the water tank area where there was the most discoloration. They were meant to be shallow holes like the others. Drill just a tad, and check. Did this four times and getting next to no reading on the meter. Thinking the hull must be think and have a lot a glass on it. Oh well drilled right through the hull. At least there was no ugly and at least this should be an easy fix later. Just need to remember to fix
