Fuel line adapter confusion...
F_R
Re: Fuel line adapter confusion...
Evinrude/Johnson and Yamaha connectors look alike, but are different size, so no they are not interchangeable.
They are all for sale here at iboats.
D
DJ
Guest
Correct! Same with some Hondas. A good design is a good design.;)
E_S_A_D
Thanks gang... I hate to be a pain , but can someone point me to the correct one for a 72 Johnson? I'd hate to buy the wrong one as we are planning a long cruise next week.
nwcove
any OMC single line connector will work on your motor, and are usually available at most large hardware stores (canadian tire here).
Tim Frank
Well, two people (and me makes three) have pointed you at iboats Marine Store...you know, the guys who support this forum.;)
If that doesn't work for you, heck, buy the Yamaha fitting...might not work, but the price is right. :eek:
E_S_A_D
I've ordered from Iboats and had a great experience. If you read the read I asked which one I need an didn't get a response; therefore, I was moving ahead.
hidef
Tim Frank
The minute you enter the iboats store there is a large sign that reads:
Need Help? Have Questions?
1-800-914-1123
They'll answer your question, and send you the right part...:)
And I did reread the thread and there may be a misunderstanding.
If you are truly after the male connector for the engine, you pretty much need to get the proper part from a dealer...part # 0376154.....and they are not cheap. The other option would be to contact one of the wrecking yards" listed in the archives/FAQ.
If you need the fitting for the tank end, the iboats one will be fine.As was suggested, match to your specific tank.
