this is the first post for me on iboat so i would really appreciate any help with info i can get
im restoring a 1988 sunbird spl 174, the previuos owner have painted the out side of a boat with regular paint and a brush. i know , why would he do that
? the boat also have 2 cracks where the engine mounts on the hull
. further more i went in the boat and the floor felt kinda funky so i tare part of the floor and guess what the stringers are rot and the foam is soaking wet :facepalm: . and surely the transom is rot
good thing i didnt pay any penny for this boat and i got it free
i took out all the foam the stringers the carpet, i mean everything everything is out. i did cut part of the hull but it shouldnt be a problem i saw bunch of videos that shows how to fix that. i took the boat apart meaning that i separated the top portion of the boat from the bottom portion i did that so i can flip the top, grind and put a layer or 2 of fiberglass cause the fiberglass it already have is yellowish and really dry like it didnt have no rasin on it. im now at the point where i need to grind the surface and start installing new stringers.
my questions are:
1-after i grind, do i need to put a layer of fiberglass before installing new stringers?
2- regarding the top portion of the boat that i separated, is it ok if attach it to the bottom portion of the boat after i install the stringers? or i should attach it back first?
3- how can i remove the paint that the previuos owner had put on the gel coat ?
like i said i would really appreciate any info thanks in advance
my questions are:
