Re: Gauge issues
Well thx but, I sorta just borrowed them
And glad to hear the gauge worked, that's good news........one down, one or two to go eh? and Yes, the video's are a great tool and relate well to what we're doing, use them.....good stuff there.
I tend to agree with ya, the sender is probably flaky, but hoping for wires........those are easier(and cheaper, I like cheap!!) to fix usually.
I think it depends on how the sender is made mainly, but a combo of both I think in our case, most(not all thou, there are probably 10's of designs out there) are like the simple ones you and I have in our boats.
The float is mounted on a rod and both just sorta bob along in the gas, the other side of the rod thou drives a wiper arm of a rheostat inside a sealed area. The rheostat is just a fancy name for a variable resistor to ground who's resistance, due to the float, arm, wiper connections, is varying proportionally with gas levels. When the resistance varies, so does the current in the circuit and the gauge is just secretly a current meter who's needle is just showing current levels......
In out case, "E" equates to low current due to higher resistance and "F" equates to a high current due to low resistance and lots of points in between.
They're actually quite simple and when you grounded the "S" terminal, you created a maximum amount of current to flow in the circuit and the meter(gas gauge) showed that to you as "F ++++".
Hang in there and plz do let me know, we'll win this war
