GT1000000
- Jul 13, 2011
- 4,916
Re: GENERAL CURIOUSITY...Would a boat with a soft or rotten floor have any chance sin
You are indeed Lucky and should takes EZ's advice and buy a Powerball ticket...
As far as how much resin you'll need, depends on how you are going to do the repair...if you do it the way that I have seen recommended here on the forum...
Make sure the wood is as dry as possible and of the right kind...
Soak the wood with resin first...
Apply a layer of CSM to the underside...
Then install using your choice of thickened resin over the tops of the stringers and held down with weights, or stainless steel screws buried in the plywood but first coated in 5200, or 3M 5200 as a sealant and adhesive...again your choice, any, a combination or all of the above...
Then apply a layer of CSM and/or 1708 biaxial...or a variation of those, as needed to level with the original deck...
You might need about a Gallon or so of resin...
Regards,
GT1M
Sweet! Im glad, so how much glass resin should Ineed for a 4x3 section of new ply?
Regards,
GT1M
