jc55
- Nov 3, 2006
- 665
Hey guys, I've done some searching and read some great tips on glassing the tops of stringers. From rounding them to adding wet strips right before decking, etc. My stringers are all in and tabbed on the '68 C-Gull... all the way up the sides leaving just the tops covered in resin only(marine plywood stringers doubled up). I'm painting all of the stringers and inner hull with Sherwin Williams Duraplate 235 epoxy, filling with 2lb expanding foam(thanks jigngrub), then decking. Will painting the tops and sides of stringers with the epoxy paint do the job or must I glass the tops of the stringers as well for strength? Thank you for any input.
