Glastron V196 restoration
Woodonglass
Depending the paint you use for the final coat, this should tell you what primer to use.
Dennischaves
Thats how I painted the hull
I followed your formula WOG with great results
use the rustoleum primer on the deck?
then go over it with my non skid paint?
Dennischaves
I didnt want to screw anything directly to my new deck so I made a platform to screw the battery box onto
I'm going to tab it in and that will be a sacrificial base for the battery box
hopefully I can prime the deck this weekend
Dennischaves
I vacumed everything really well and wiped it down with acetone twice
after all this work the last thing I want is a paint delamination problem
* should I add hardner to the primer and should I sand between coats of primer?
Woodonglass
No hardener. Light sanding with 180 grit between coats and wipe down with a 50/50 mix of Mineral Spirits and Acetone.
Dennischaves
It' nice to start putting some things back
I bent new aluminum to trim out the transom
it only took 3hrs (shaking my head) but looks good
Baylinerchuck
The feeling is amazing when you start putting things together, instead of tearing apart. Nice work!
Dennischaves
Thanks baylinerchuck
What should I use to glue vinyl to wood for the new trim panels I made?
ACon977
Very nice project and a fun read, thanks for sharing! You have some very impressive paint skills, the hull and motor look amazing.
Dennischaves
Thanks again fortunately I do autobody for a living and it lends itself alot to this project
tonight I got the first coat of non slip deck paint on I got a free gallon from total boat and it seems like nice stuff hopefully tommorow I can apply the second coat and remove the tarp and start the new seat bases
Dennischaves
Yes I primed it
I wet sanded the hull and buffed it
looks really good now
and I finally got it back on the trailer
Dennischaves
I' going to seal all the trim pieces today with the old timers wood sealer
how do I apply it
do i apply 1 coat and wait until tommorow to apply another or do I just keep applying it until the wood won' absorb any more
also can I paint over this sealer
Dennischaves
I got all the trim pieces, dash and the seat bases cut out this afternoon
it ended up being more work than I expected
now I just have to seal them with the old timers wood sealer
Baylinerchuck
Yes, paint old timers on until the wood won’t absorb any more. Really soak the ends. I painted over all of my wood after applying old timers. I used the rustoleum top side paint, however, I’m sure you could get away with a cheaper paint.
