Baylinerchuck
- Jul 29, 2016
- 2,740
I think you can use the 1700, you just have to use CSM first, and between the layers of 1700.
There's no need to use epoxy to glue the transom to the hull. Thickened Poly will do a great job. Thousands of restoration prove that fact. Remember...Epoxy sticks to anything Poly will NOT stick to Epoxy. I'd Highly Recommend that you choose one resin and stick with it throughout the restoration. Poly would be my choice.Im a little confused now
Would there be a problem using epoxy to bond the new plywood transom to the hull?
Then i plan on doing the tabbing etc with polyester
I just liked the idea of the bonding strength of epoxy...any thoughts anyone
Also how should i seal the wood for the bolt holes for the outboard ....coat the inside of the holes with resin, a piece of pvc with the same inside diameter as the bolts?
