Glen-L WB Power Skiff Build
zool
A buck a clamp must be for the alligator type, The final stages of the wales will approach 5 1/2" wide, so i need C or Bar clamps, I see HF has 12" bar clamps for 3.99 and 6" for 2.99...seems like the best deal i can find....a few dozen of those, plus what i have should do it.
zool
I got a few hrs in today to fillet the seams, got the whole main section of the hull done.
y4mSa-vS9j6gycsau6eE19fuTixsWbWitSNlzhflv5Hkf6CDk_BFD7b3I-zc3F9XTmZziHwUlnksXdK2f1O3nbA2gOPbtZJaL8tI7HMX3zChikOjvk6ilNWaDmHbqArffsHMqzXnfC91V-RcsZWdWvcE--6rFnuRzLW2-Cl2NX_W3WQUV0UpDTYgioSCyuTyCZ-8M1HepzMNO6kc-4MY4ynQg
y4mot3ampa1Fc7WjZJuzU8m1RPdBypAW1oF6XnzADN7wbUQRsRHvzP4dIv2c_CZlPWKG4j90cfdSFeS6-6Qt1EDeu7hX5PqhrMW0P_3Re8QqfaZOFY7mPuGem3RO6TYOzmNYXQAZQRgDSbwb00BVXYi1B9M_XsR1JmMdQQFgDQUdftAuPx09w001ps33jDmnhqSXtixRdbdSTgWy8JSe3J5qQ
I kept the coves all relatively small and tight, especially at the transom and front bulkhead because im planning to cover the transom and bulkhead with 1/4" x 4" oak appearance boards, and varnished to simulate a planked transom.
y4mvdOHQ5mJNSIRByfgVMJNYuTKk1gmhh4pXI-d6_mDECM0GXYUVEAYe4SnkBdwHAzEtoJzQi_kD_ZhNmn-Ca7WHSoxHnjhWFcWEZpybgZAVvDG5sgRWM5al1GmF8-sg7eqIg7mA2XBJxihK6et11E5xV2I9HmaZkufI29vVxeLweBErkKWAidoNYZa8DZ1eavcxotPZidlIABEVkFeeoznyQ
y4mGdd1c8gdX9QhmXfwG85QG6dXe_Ig47HD_eG8IpEfxb23LjkRGtGat-FlmFjEJM2boT80dgrAHjH7N2VSXyLX_TK1VOYcn4x2LI4YTadHIeU8O9ZbVwCwqp4mimv7b2zJ0qBTZeKmH66J1yrAn9k5zbr8RBW60-0To1p3uerQFjcz51-ASn5plDPY-dKj1Aai_36dTsTAavaWF6kWzYGR9Q
Its hot this afternoon, and working time is short with the 3:1....I may get back out there this evening tp tab in the seams with 6oz cloth if I can.
kcassells
nurseman has thousands of clamps he won't give up. Say what?
fishrdan
Don't just throw a dozen of those into your cart and check out, work each clamp through it's entire range to make sure it's a good clamp. Last time I bought those clamps, I rejected half of them as the screw wasn't smooth or the bar had a defect causing it to bind....
Pcolafisher
Sorry, I typed resawing but my iPad keeps changing it. It took four tries this time to get it to take. Cheers
zool
Yea, good call on that, their metal and machining sucks...usually, if it doesnt have a motor or a switch on it, I do fairly well at HF..
Thanks!
zool
Where are you finding 1/4” oak? Or are you reshaping yourself? Cheers
Home Depot and Lowes both carry 1/4 and 1/2 red oak boards from 2" wide to 6" or 8"...but only up to 4' long
Home Depot calls it hobby wood I think.
mickyryan
look into pallets, there mostly oak and if you look hard enough quite a few are nailed with extremely small staples so you can get them plane them and save money :)
mickyryan
btw best ones i ever found were for commercial refrigeration and stainless steel equipment some were 6 to 8 ft long :)
zool
most of the pallets around here are pine...at least the ones I get my hands on...
Go to your local cummins or cat dealer. Engine skids are oak and they have to pay to dispose of them
Woodonglass
Truckers use a LOT of 4x4 oak to keep their loads from moving around. I found a place that supplies them. I can buy 4x4x8 ft red oak rough sawn for $5.00 bucks. Sure, it has some knots but I just cut em out or work around em. I've gotten a LOT of nice wood from them.
