Glen-L WB Power Skiff Build
zool
y4mkRywNFZxXx8s2JWL6I1XyP130tvcU7Waci2QKFqTyN9LyVrsRgq0rIp4qUn9DARzb-oDCWafAATymF8MOeCoQwXVfw0yq0bw8_OIXY3p1m_ycbSAzcs63vldxD3Kxn-_5X6ZsKve5Lc7I_5EQML1hUZ0heZtvdpb4vceDcHvs6MFSmmPKXDnZW9p1NE56Dg2GgJUPK8EMhFZlm39AgAlDg
y4m_ToJMevle5yzCE0qCZtt5XP5gfWri5snUkIYT_hCRJFw9aTkIsJHJ80TF4j2n2MVgECuJhGO_m9nbc1YWykiQ8OaTT1lh02XX-u2Ob6wi2SKK_USfEyeibePtF9dNKIp9YqPteudcBqURVcm7YlSvQ4RsDzxM3Zt5Nzo_jx8x7MDYT_IefFH-fySM2a1i4UkAL89IA8joN7cqtVGyE1oUA
zool
y4mLe_2WBfT25gTL0FEW27MCW0W261aq76ujqnG553PmDyofmfB0A3etk69XBp3W64JudbfgoWdycKKiVxz2Oq9hjWQBJfn2U4ygEnEK549sAJQR7blZUK1ZYFfdcYl0cPTldrUs5ezgYRB5LEFgKq1LxvK6Nw3VjgYmrZKZ9CwjS1anfmqZKlMdQN3UWAvxGmNvS2ZqZdHeV8Y8wI8SRtU7w
Started setting front side panels loose, have to notch them for the bow deck supports
y4mblQn_jizNnI1oWdOhAuHAR8S1MYTIiNLhpMoJrIm15vCCD9h1DkLWPlu-Z1jxWWHl74CfnYYMJCQsjIDssGotmKH32IFjFhaoX9P-rk9ZHQHlxoDGEikN88izALl4VWQuB1wunwi2u0Nfs2ZBFvKlMlgkhD5w8SzCIGBVH-AZ5G05ioipwCoyAQ71OlXILhu8B9Wi8WUZiqh22n5HiypIQ
mickyryan
loookin great man , i still dont know if i ever wanna fool with eeeeeeepooooxyyy lol
zool
Thanks Micky..Epoxy is easy and forgiving....unless ur allergic to it, like me lol....my hands look like a lizard after that long session.
oldrem
Been using epoxy over 50 years - don't think I ever want to use poly resin. Thankfully it hasn't effected me in anyway I'm aware of.
mickyryan
I guess i am just the exact opposite of old lol i have used poly exclusivly lol but if i was working with a wood boat id prob, bite bullet and use epoxy.
pekstrom
Hey zool you're making some real nice progress. How have you liked working with the Glen-L plans? Did yours come with full size patterns? I just ordered me a set of plans for a little bit bigger boat than what I have now. Based on how they describe them they sound real nice. Have they been easy to follow and also have they made it easy to cut the frame parts?
kcassells
Just wondering how the Imperial is doing? Like you don't have enough going on. Just asking.
zool
Sounds like ur walking on egg shells asking that question lol...Shes ok in her cocoon, I left off with the decks going back in, but one of the cleats failed, so the forward deck has to come back out...I uncovered it last week to air it out, let the rain wash out the hull bottom....gonna cover it back up, prolly wont be getting to it again til next year.
zool
Thanks Pek, No complaints with the GL plans, pretty straight forward and easy, at least for the skiff.They call them full size, but they are 1/2 from the center line to the gunnel, you just invert them for the other side and to make a full size pattern.
The frames on mine were sacrificial, or u have the option of leaving them in.....
If u dont mind me asking, which model did u choose for ur next build?
pekstrom
Ok great. That's kinda what I gathered from reading their descriptions of them. I have been looking at the Par-Tay boat as they call it for a while now. I'm pondering the 20' 6" version. I measured the garage and it will be real tight so not sure I'll pull it off. Of course our little Squirt (the 13' 9" PM38) will have to move outside before I can do anything because she sits in that spot. Not sure when I'll start though. Could be a while.
zool
I must have missed their par tay deck boat plans..the outdoor kitchen is cool for that type...
y4m55wmCYgzIm6Z9kGbWSCcC7OH6vgEOzIQ2ZnZfylLLWhRevfA8OTHbofYL1nJuU0lGQb6E3XYhkj5AV6gO5t75l3SsiVtpl7TGDpHeEgj3ADjR0y6Ch40pIe0sioU9s9gN5vvPHNLT3yUkuq_i84N_S_rDD03tu123F8C_3UAe1mwunEQxbvmGfXpzGdTCs9RV-WhG9K3Gn363uziIO1paQ
zool
The cam follower for the OB came in..so I threw that in today to see if it solved the idle problem......and it did...starts on 1-2 pulls, and idles without effort now.....the lever wouldnt go into reverse, but after I greased the zirk fittings, all was well
So I decided to clean up the lower and prime it for paint.
y4m3kYmmnhbUZAxxEI_x7bksJ0We9Adm3ipDtoF9lKFQ0tqbaaZfZdEempiGlO0H2Dxkg_woetsFf4BX31_GYzBHjT_47At22O-YwLsKEYVskstNs7jYzKU1fxDlTnsEz2IqPUzcv-AtI1TJeg3H3QH8FWuDV_OX6nXQRcN7EQNrrpxdNQgVnF0YaWzGZG6NnXQwAFNCQVg1kfytWBrry5kyg
y4mAK2c2v5h6XEl2jiCFpBJcFggifLVBcymy4uP8paq1vbO7zkqpBSAqXKFzgj5EhKYh9nn_XyLf30joL-Tstp_76dhP0AbOymSCtlsTNFK41OrhpwP-gKxs6Tnvs89cxyKRsCq5ZLUNQzkLytZ7DFroqI1TN1G2-4Bn3D4rt3QjjhCNpjrZKwaovNN-8Fi4jdFv2KFFa_iPImK1jNOPoKXOw
kcassells
I spent time on the site last night. Some good thingys there to paruzz. Looking good Zool.
Pcolafisher
You might also want to check out Spira international. Jeff Spira has a lot of easy to build designs.
Cheers
sphelps
Glad you got the o/b issues worked out !
Fresh primer looking good !
