thanks ahead.<br />'used johnson 140 OB with rebuilt head'. compression 125+ in all 4. runs good. <br />problem is the swivel points on the motor were not greased properly and rusted causing sticky left/right steering movement and a popping, metal to metal binding sound when tilting the motor up for towing. I see 4 grease fittings (2 for left/right and 2 for up/down). Do I change fittings,lube and use some WD40 or disassemble (shop work)and start from scratch?
