workaholic
- Nov 26, 2008
- 101
I have a 1981 Merc 200hp (V-6). The motor has a really hard time starting. I have to crank it over alot and choke it more than usual. When it does start she doesn't run on all cylinders write away. I have to drive it around for it to warm up then she goes like hell on all cylinders. I tried changing the spark plugs out for new ones (NGK BU8H) but still the same.
I have not yet done a compression check on it.... assuming all cylinders have all good compression I would guess its a fuel issue. Can the fuel pump be going on it maybe?
THanks in advance!
THanks in advance!
