Does anyone else have problems like this? I have a barely used '98 25hp 4 stroke yamaha, I can't even leave it alone 2 weeks and the carb gets crystallized crud.gas in it, i have to take it apart completely and clean jets, bowel, etc.. It does sit in 95F temps outdoors (N Fla), but this is rediculous, I use med grade gas, new gas usually w/ gas extender additive, tank is clean, lines/filter are clean, but this still happens, even if i drain the carb after use, alway discionnect the gas line, apparently there's enough drops of gas left in it to crystallize. Is this typical for all 4 strokes, or is this model famous, and finally, other than storing it in the shade, i need advice on how to leave it anywhere from 2 weeks to 2 months without this happening? This summer I have to disassemble/clean it 4 times already!!!
