Re: Help i have a water leak....
Have you tried loading the boat on the trailer ****-eyed? That way you can see the areas that rest on the bunks, and check for problems. If all looks good, then I'll go back to saying water trapped in a forward compartment.
You'll still need to figure out if the water is 'new' water from each time on the water, or if it's trapped water. I'd still double check the pass throughs from the forward compartments. And it doesn't sound correct that a forward compartment (below the deck) would drain onto the deck and then to the bilge. I think you thought I meant the forward seating area. Below the deck, there are numerous compartments, and the water has to be able to travel from one compartment to the other, and to do that, there are pvc pipes between each area. It is not uncommon for them to get plugged up with debris. Those are what you need to check are clear, otherwise a compartment will accumulate water.
yes i have plugged the little pvc pipe in the ski locker thats how i know the water is seeping in from around the pvc pipe while in the water.
If you have access to the other side of the pvc pipe, and all looks well on the hull from the exterior, seal around the pvc tube with some 5200, but
only if you've confirmed that the pass-throughs are clear.
